BlackVue DR3500-FHD (black, external GPS)
alexsoll
alexsoll
Retailer
Minsk
Belarus
Street Guardian, BlackVue, Thinkware
alexsoll
alexsoll
Retailer
Minsk
Belarus
English is the official firmware
alexsoll
alexsoll
Retailer
Minsk
Belarus
new firmware not recommend, there are errors in the settings of the video qualities.
Pittasoft messed up options + is periodically disconnect gps (previously this was not the case)
alexsoll
alexsoll
Retailer
Minsk
Belarus
docwychwood
Hi, I have the Korean version of this camera (DR3500 FHD), I have tried converting to the firmware to English (as described by altering the version.bin file) but it has not worked. Is this possible, am I missing something?
Thanks in advance for any help you guys can provide.
miata22
Hong Kong
Hello all, I am new to this forum and would like to get some advice from the experts here.
I currently own a DR-500GW, however the cam malfunctioned due to heat problems and it past the warranty period, I already tried to fixed it but the internal battery soldering point is burnt so there is nothing much I can do.
Now, I am looking to buy a DR-3500, it seems the cam does not have any holes for ventilation, does anyone knows the DR3500 has major overheat issues?
Thanks so much
alexsoll
alexsoll
Retailer
Minsk
Belarus
3500 is a good model, a size smaller than 500, the heat didn't notice, I recommend
miata22
Hong Kong
Thanks for your advice and may I ask does the power supply connector is same as DR500GW? If is the same, I should be able to plug and play without re-wiring the power connector.
alexsoll
alexsoll
Retailer
Minsk
Belarus
Yes, 3500 and 500 connectors are the same
docwychwood
I have had this model for 4 weeks now. No overheating issues though it does get slightly warm to touch.
miata22
Hong Kong
Thanks so much, now is the time for me to decide between 3500 or 650....angel vs devil in my head at the moment....haha
alexsoll
alexsoll
Retailer
Minsk
Belarus
Android App 1.76.apk
1. Speed Alert function added (Model: DR500GW/550GW, DR600GW/650GW)
2. User information registration function added (Model: DR500GW/550GW, DR600GW/650GW)
3. Time synchronization function added (Model: DR500GW/550GW/500W, DR600GW/650GW)
4. Pop-up for using user location information added
5. Support Landscape mode (Config > App Setting > Support Screen Rotation > Auto/Horizontal/Vertical)
alexsoll
alexsoll
Retailer
Minsk
Belarus
Android App_1.78.apk
- Required Firmware : DR600GW 1.001 / DR650GW 1.002
1. Speed Alert feature (Models: DR600GW/650GW)
2. User Info. Registration feature (Models: DR600GW/650GW)
3. Time Synchronization feature (Models: DR600GW/650GW)
4. FOTA Upgrade support (Models: DR650GW)
- FOTA upgrade will be available after F/W 1.002 is installed on the BlackVue.
alexsoll
alexsoll
Retailer
Minsk
Belarus
