Bracket issues?
Fennaman
Netherlands
Received my DDAPI mini 3 from China. Works fine. Only how to use the bracket in combination with the hardwire kit.
The camera came with the standard (cigarette lighter) wire. Only the hardwire kit has USB mini jack. And that jack can not be passed through the bracket to the camera! Or should I use a drill to make the hole large enough?
I have included some pictures.4521745218
someone posted here a few days ago about the plug changing on the Mini3, have a look for other posts in the section you should find details
Update:
So basicly I understand it is as follows;
  • Buy DDPAI mini 3 from Aliexpress and receive the one with the headphone jack mount. Use cable in box and connect to the car sigarette lighter. Camera works. Parking mode does not.
  • Buy DDPAI mini 3 from Amazon ( https://www.amazon.com/gp/B078N51Q8Y) BE SURE TO LOOK FOR DDPAI TECHNOLOGY SELLER and receive the one with mini usb mount. You can than use any 1,5 V hardwire kit with that connector. Camera works. Parking mode does not.
  • Buy DDPAI hardwire cable set ( https://www.amazon.com/gp/B07P5QH8ZR )with 3,5 mm headphone jack from Amazon and assemble in car. Connect with the 3,5 mm headphone jack mount.Camera works and also the parking mode.
  • When a hardwire kit ( with USB mini jack ) is allready installed in car (as is the case with me) and you don’t need or want the Parking mode AND got the headphone 3,5 mm jack mount delivered with your new mini3 than make the hole on the mount larger. Use an electric drill (or better electric rotary grinder) and proceed with caution! Then install mount on the windshield and connect the USB mini connector jack. Camera works. Parking mode does not.
  • Buy a different make and model Dashcam.
45221452224522345224
G mini3 2
N mini3 3
