Hi All,
So i drive quite a modified truck with lots of accessories on it. I was robbed the other night and had some stuff stolen and i want to try and stop it happening again. I would also like the camera's for general dash cam use too as i can understand their effectiveness.
So, I'm looking at 2 dash cams (Or a 2 channel system) that has an equally effective parking mode.
I was originally planning on 2 0806 camera's with 2 x 64gb cards in each, so 128gb of recording per camera and just leave them connected to a permanent power supply so they record 24/7. Doing it this way should get me over 24 hours of footage per camera i think?
Then i started looking at something like the Blackvue DR650GW 2-ch as it won't cost any more than the above setup. But I'm a little unsure on this. I can only use a 64gb card per 2 camera's, so thats a 1/4 the capacity i could with 2 0806's. Im assuming that the blackvue's parking works on motion detectors and thus in theory will actually be able to record far more as i wouldn't need to leave it running 24/4. My concern with this is the rear camera will be recording through a tinted window, and I'm worried the motion sensor won't be effective enough. I also read that on a lot of camera's (Not sure if it effects the blackvue as i know its a little more upmarket) that you have to leave the camera in motion detect mode all the time (or switch between it every time you drive it instead of leave it parked) and that this isn't as good for use as a dash camera?
So my overall question is, for my application, what would you experts do?
Rich
Rich
