Below is a full reset as provided by Millie at Nextbase, I have basically copied and pasted. It may help.
too: Do you also have the latest update R23.7 ?
PLEASE NOTE:
- Following this process means that videos saved in the "Library" tab within the MyNextbase Connect app WILL BE DELETED. Please ensure you saved these files to your computer or laptop before proceeding if you wish to retain any files.
- Ensure your Dash Cam is plugged into a power supply throughout this process.
Steps for Dash Cam:
- Stop the Dash Cam from recording by tapping on the flashing recording icon at the bottom left of the screen.
- Tap the settings (cogwheel) icon that appears in the top left of the screen.
- Select "Setup" to enter the setup menu.
- Swipe across and tap on "Keep User Settings" tap "OFF" and tap OK.
- Locate, then tap on "Default Settings", tap "Yes" and tap “OK” (Your Dash Cam will restart).
Steps for iPhone
- Open “Settings” on the phone.
- Select “Bluetooth” to enter the Bluetooth settings
- Locate your Nextbase Dash Cam in the “paired devices” list.
- select the "i" button on the right-hand side and “forget the device”.
- Delete the “MyNextbase Connect” App.
- Restart your phone.
- Reinstall “MyNextbase Connect” from the App store.
Your Dash Cam will restart from factory settings. Now follow the
first time setup process again to get connected, making sure you agree to all of the
permissions requested by the app (Bluetooth, Wi-Fi, local network etc).
Please visit our help centre article
"Can't connect to MyNextbase my smartphone" if you would like to see images relating to each step of this process. When followed correctly (and in order) this process fixes most issues customers experience.
Kind regards,
Millie
Nextbase Technical Support
