Hello,
about 3 month ago i bought a DR650 and i am running it with a 64GB card. The first month i had no problems with cam.
Then the temperature dropped and some times the cam seems to run at start up and later it told me "SD card problem". I plugged it out removed the SD card and "cleaned" the contact with my fingers. After insertion and plugin it worked very well.
Currently i have the issue that the cam seems to start normally after plugin (i did not install power magic yet). The record LED is on, then it starts blinking and the GPS LED is on. But after some minutes the record LED turnes off and the GPS LED stays on. First time the cam stayed in this state for 2 hours.
Today i restarted it, the cam behaved same as described above. Then i connected via wifi. I tryed to change some configurations but during saving the cam went to its "error state" and wifi did not react anymore. It seems that it was freezed/crashed.
The log files (SD-card/BlackVur/System) have no record from the startups that ended in this crash/freeze. Regarding the log files i am currently using firmware version 1.000
Does anyone have an idea what i can do? I will try to update the firmware tomorrow and see if that changes.
