So far the swapping the SD card has no positive change to camera failing to work.
I tried disconnecting the rear camera and still the system fails randomly.
I am now testing using the power Magic pro using both the ACC and BATTERY connections switched ON.
Next test is to swap back to the 12v plug and remove the power magic pro. Possible issue could be CANBUS interfering with the power levels.
Test after above swap the camera from wife's car to mine.
