rcg530
- Jan 23, 2021
- California
- 70mai, BlackVue, Thinkware, Vantrue, Vueroid, VIOFO
The BlackVue Power Magic Ultra Battery (B-124/B-124X) Accessories page is located here: Power Magic Ultra Battery (B-124/B-124X) AccessoriesIf I have the right pins to fit in the connector, I might be able to splice the DR900X’s hard wire cable to the B-124X supplied 4 pin connector, but I’m not sure. Do you have a URL for the cable on the Blackvue site, even if it’s not orderable?
When on that page you need to make a selection in the "Accessory Type" field of "Dashcam hardwiring power cable (3 wired)."
To see the picture of that item you need to click the "\/" down arrow on the left side and then click on the picture of the item.
The B-124/B-124X battery packs have been available for a long time and during that time a vast majority of the BlackVue cameras have been 2-wire powered cameras until the release of the "X" cameras. I would totally agree they should refresh the list of included items for the B-124X to now include this additional "Dashcam hardwiring power cable (3 wired)" as a standard item in the product bundle.
Here are the items I purchased from mouser.com to get the DR900X 3-wire hardwiring cable capable of being connected directly to my pre-existing battery pack. I also purchased some "Clip-on Ferrite Ring Core RFI EMI Noise Suppressors" and I used one near the end of the 3-wire harness that plugs into the dash camera battery pack. There's a noise filter on the BlackVue cable as well.Happen to have links for the molex connector and pins on Digikey or Mouser perhaps?
RECEPTACLE 4 POS SINGLE ROW (Molex connector for wiring harness end that comes from the dash camera)
MF 3.0 TERM 20-24G F Cut Strip of 100 (Female terminal connector pins - for wiring harness end that comes from the dash camera)
If you are interested in the dash camera side of the connection:
PLUG PANEL MOUNT 4P SINGLE ROW (one version of the Molex plug connector that's on the battery side of the connection - this one has extra external plastic tabs that I ended up cutting off for my installation)
MF 3.0 TERM 20-24G M Cut Strip of 100 (Male terminal connector pins)
