2
(intense sunlight or artificial light) wonenvironment still can record the objects details. Support Time-lapse photography function, can setup the difference period of time to take photos. Under the video mode will automatically synthesize the photos into a video. Ittorage capacity but also could have the special efficacy that the quality is the same as the professional camera. With loop recording function, it can automatically delete the old file and record the new one. With seamless recording function, it can ensure no missing during the recording. Support the motion detection to save more memory space, this is function is adapted to use on hunting cam. With the image rotation function, you can conveniently install the product to variety areas with attached brackets, and guarantee the correct direction of the recorded data. Support Burst 30FPS. With the self-timer function, you can capture the ideal picture by the monitor preview. With hot-key function, itom in/out. (Notice: Zoom function is available when the Watermark and Function watermark is off.) With the time/date/G-SENSOR/GPS (optional) speed watermarking function can ensure the status, time, speed and positioning coordinates accuracy of the record file. Incident forensics is more powerful. Support high capacity SDHC card up to 64GB (at least 4GB, and Class 6 is recommended). Support DC12V to DC24V, and plug and play can be realized on heavy trucks, big trucks and buses. Supports CVBS/HDMI output; using the special output cable of this product, you can share all kinds of wonderful videos and photos of yourself and your family, and play files on TV screen. It can be used as PC camera to bring you an enjoyable network life. Built-in microphone/speaker and dual-channel stereo output bring better sound effect. This product has passed Taiwan BSMI certification and international safety certification of CE and FCC, and it is manufactured in RoHS lead-free process; lets work together to love the earth and protect the environment.
Please do not use or place this product in the dusty, dirty or sandy areas, or the components will be damaged. Storage temperature: -20℃ to 80℃. Operating temperature: -10℃ to 60℃. Please do not drop or strike the product, because the violent vibration may damage internal components. Please charge the battery fully before the first use. Please tear the lens-protector to first use, ensuring the video clear. Please keep the camera lens clean and do not use the objects which contain oil or water like fingers to touch the lens, because it will dirty the lens to produce hazy mist or halo effect, and finally lower the quality of videos. We would like to recommend that you regularly wipe the lens with lens cleaning cloth to maintain the high-definition and clear shooting quality. Please don’t wipe the lens with toilet paper or general paper to avoid scratching the lens. When using a new mircroSD card, please format the card in the camera to be sure it is set to the correct settings. Please use a correct microSD/SDHC card (suggested minimum 4GB card with a class of 6 or above). Operating system: windows 7/Windows XP/Windows Vista/. Please make sure the product operate properly before using Because the battery is the principle of using a chemical reaction, so as the time increase and the battery performance will be reduced even if it is stored for a long time without using. If using conditions such as charging, discharging, the use range of situations and the ambient temperature is not specified, also can reduce battery life or damage products ,and it will not be covered under warranty. Notice
