Capacitor Replacement - SD Card Error
ssb-tech
My 550 keeps giving me the 'Please check SD card' speech. A power cycle and re-seat of the card seems to help for a while.
I dismantled it to see if there was anything visibly wrong with the solder pads where the card slot sits and it looks fine. I did notice the capacitor was bulging, and I do know failing caps can cause all sorts of weird issues. Has anyone experienced a failed cap resulting in the SD card error and resolved it with a new cap?
Yes, I've tried new cards.
Thanks.
Thanks.
Bulging caps not a good sign.
Tip - cut them off at the legs instead of trying to desolder. Then you can desolder the remaining legs without potential damage. ( I don;t know your skill level that's why I'm suggesting this.)
I would also look for dry solder joints on and around the SD circuit.
Thanks. The socket pins look good. The capacitor I ordered is slightly too big so I'm waiting for the correct ones to arrive from an eBay seller half way across the world. Not sure why BlackVue didn't go with a more common size.
I'm feeling naked without the camera running. Can I run it without the cap in the circuit?
I don't like using my car without a dashcam either. I feel your pain lol
Can't answer the question about the cap as I don't have a circuit diagram to check.
Once you fit the new cap let us know your results.
Update! The capacitors finally made their trip halfway around the planet. I installed and so far the camera is working OK.
I'll need to pull the card to check the videos - previously they were getting stuttery. Hopefully that's been resolved.
But at least it's not giving me the error any more 🙂
