- Sep 5, 2018
- China
- AZDOME M06P Real 4K Dash Cam
Dash cameras are becoming more and more popular among motorists around the world. There is a growing desire to capture fascinating events on the road and we hope to replay them afterward. As the name suggests, it is usually placed on the dashboard and sometimes connected to the windshield. This guarantees a magnificent view of the road ahead.
But a dash cam installation can be a very technical thing. This guide will show you how to install a dash cam in your vehicle. My ideal advice is that you get a professional to do this installation.
1、 Where to mount the dash cam:
You buy a dash cam for the purpose of being able to easily determine its location in your vehicle. The dash cam is designed to record the events in front of you through your windshield. While the name provides clues as to where you should put it, some people prefer to stick it on the windshield. Whatever the case, it's best to put it in a position that doesn't get in the way of your sight or distraction because you're driving. Two common locations that seem appropriate are your dashboard and your windshield. You can also become creative, but just make sure you get the best out of it and it won't be too far from the power supply.
2、Find The car’s fuse box:
The sprint Cam is powered by the car's electrical system. It connects to the power fuse in your car. You need to know where the fuse is, your car. This is critical because it will also help you determine the location of the dashboard camera. Typically, depending on the car, the fuse box is located below the sprint, either on the driver's side or on the passenger's side. If you can't find this yourself (which would be very strange), you should refer to the manufacturer's Guide. If you find it difficult to access it even if you find it, I always recommend that you contact an expert. After all, the dash cam installation meets their job requirements.
3、Rout the dash cam cable:
Before installing the dash cam cable, you should do a test layout to see the length of the cable, whether it covers the distance between the dash camera and the fuse box, and how much relaxation should be left. This is a great way to know how to run your cable in its appropriate way. Routing your cable usually involves removing the internal panel of the vehicle.
Wires should run inside these panels, such as a panel, so your car doesn't have a cable hanging around it. The first call point was to pick it up through the rearview mirror and get into the front page. The headdress should be properly hidden. From there, you can run it through (below) a-pillar. It may be necessary to close the panel so that you can run the cable with other wires that are already embedded in the a-pillar. Then run the cable down through the B-column until it reaches the position where the fuse box is located.
4、Find the right fuse:
In each typical vehicle, the fuse box contains a fuse that is always hot (living) and a fuse that only comes alive when the vehicle is moving. It is best to connect your dash cam to a fuse (hot-start fuse) that is alive while the vehicle is running. With this, your cam will only open when you turn on the ignition, and it won't close until you turn it off. This is the ideal approach.
Use the power tester to see if it is a "hot start " fuse. Turn on the ignition device to see if it's powered on, then turn it off to see if it's turned off. Do this until you find a fuse that is controlled by your ignition. Then take out the add-on fuse circuit and install the original fuse of your car on top. Inserts the circuit into the selected fuse point.
5、Install the rear dash cam
6、Test the dash cam
6、Test the dash cam
