DashCamUser123
- Jan 29, 2021
- Ontario
- Canada
- A129 Duo x 2 / A139 3-Channel / A229 Plus 3-Channel
I am using a refurbished P8. Had it for a couple of months but only just installed. I had used the Cellink Neo Plus app previously but have forgotten what to expect.
1) I started with the P8 on its own. It shows 7500 in the battery setting of the app. Parking Mode showed (if I recall) 36 hours* run time. Viofo A139 front + interior cam only.
* I don't recall the runtime being that long before using only the P8. That's because I always had the Cellink Neo Ext battery attached.
2) After this setup ran good for a week, I added one Cellink Neo Ext. battery. The app Ext Battery setting shows 6800. Correct.
3) Once the setup was fully charged, Parking Mode showed similar or slightly less parking mode runtime to using only the P8 on its own. This can't be right.
4) I turned the P8 off and restarted. That didn't affect the parking mode runtime hours capacity. It was similar to just using the P8 on its own.
Did I forget a step in the setup?
