If so , what is capacitors function ?
BTY what is the current consumption in a motion detection stade ?
An indication that the capacitors are working is that the REC button light remains lit (provided you have the LED setting set to ON) a few seconds (mine stays on 6-7 seconds) after power is removed or the car ignition is turned off.
Power consumption measurement: Motion Detect Mode
Measurement device: Keweisi USB inline Volt/Amp meter at the output of a 2.4A wall charger.
Environment: Indoors 75 degrees F.
Configuration: 2.4A wall charger - to Keweisi inline USB V/A meter - to supplied long cable (A119S) - to GPS mount (A119S) - to A119 Camera. Sorry the A119S components were what I happen to have on hand at the time but as far as I know they are the same. Camera and components are of the V1 type.
Key settings: Motion Detect ON, Resolution-1080P60, LCD Display-OFF, LED (REC light)-ON, WDR-ON.
Additional Info: Motion detection ON activated by TV screen, OFF activated by covering lens. Average current determined by measuring mAhrs/hrs over 30 minute or more period. Only one measurement made for each case (recording and not recording). Power consumption is the best single parameter for comparisons since it considers both voltage and current (P=IV). Power consumption includes that of the camera, GPS mount, the cable, and the measurement device.
Measurement (recording): Voltage = 4.88Vdc , Average Current = 0.568A, Power Consumption = 2.77 Watts.
Measurement (not recording): Voltage= 5.02Vdc, Average Current = 0.259A, Power Consumption = 1.30 Watts.
