avaire
- Jun 29, 2021
- USA
- A129 Plus Duo
I apologize if these images are huge
I am trying to hardwire my Viofo A129 Plus front dashcam to a Chevy Cruze LT 2016. I've identified a fuse here that only has power when turned on, it's the 5 amp that is brown on the bottom row (the fourth from the left). That particular one is for the shift lever illumination which I honestly don't know what that is referring to, I hope it isn't important. I found a fuse that always has power on, the 20 amp all the way to the right which is for the radio. You can find the mapping here
It is proving difficult to hardwire my dashcam to the point that I am considering paying someone to do it for me. When I take the fusebox cover off, there is this frustrating plastic horizontal bar that makes it hard for me to get access to the ground. In the first picture you can kind of see it in the bottom right. Actually, you can see it more clearly in the second picture. I need to screw the black ground wire into that somehow (don't know how) from my Viofo hardwiring kit. It is super cramped.
What should I do? Is it possible to remove the component with the horizontal bar if I tug hard enough? I don't want to break anything and I don't even know if that is meant to come off.
Also my tap-a-fuse came with only 15 amp blue fuses, don't I need 10 amp ones? Do I have to place yet another amazon order?
I was also wondering if I would lose the so-called "shift lever illumination" and radio if I messed with them? Do I lose their functionality if I work with them in hardwiring my dashcam? Thanks
