singlespeed
- Mar 17, 2014
- Australia
I thought I'd share my Pano II experience between my two cars that each have the "2014" Panorama II/S model in them. The cars are a 2014 Volkswagen Golf TDI, and the second is a 2014 Toyota Hilux SR5. I'll start with the bad.
In the Hilux it has the typical Japanese car behavior in which everything is powered off when you start the car. The Pano powers on while the ignition is switch to ACC/ON, then it loses power for a second when the key is turned to start, so in each start of the car it effectively gets interrupted in its first startup then attempts to operate normally when the engine is running. It's quite often the camera protests being interrupted by going into a reboot loop which I assume indicates that the data on the SDCard is corrupted. The only fix is to swap cards or quickly (I have about 5 seconds to finish) a format of the SDCard. It's unfortunately Japanese cars behave this way, it's equally annoying if I'm on a bluetooth phone call and I have to the start the vehicle, this causes the radio to lose power and restart, during this time the call is reverted to the mobile handset then has to reconnected to the radio. I feel my option is to live with, knowing I have swap/format the card about 25% of the time, or I will hardwire in a switch that is still tied to the ignition so I can keep the power to the camera off until the vehicle is started, but I'll leave it switched by the ignition so I don't forget to switch it off when done driving. Yes, I know the mutlisafer could be used, but I don't have a need or want it to record all the time, nor do I want to be forced to turn it off manually.
The Good:
The VW's handling of it's accessories is brilliant, once the ignition goes to ACC everything remains powered up, this means that camera starts recording goes on before the car starts and is not interrupted during the starting process. This goes for the radio/bluetooth as well. In the VW I've never had an issue with a corrupted card requiring a swap or format.
I wish Toyota would have wired everything off the ignition, but not interrupt the circuit during start up. To compound the Toyota's issue is that its glow plugs can require warming on cold mornings, this makes the ACC to START delay a bit longer which only serves to aggravate the Pano even more. It's worth mentioning the VW has instant start glow plugs, but it wouldn't matter anyways, constant power is a beautiful thing.
It would be great if there was some sort of "startup delay" in these camera so they sensed power then delayed their boot by 3-5 seconds, this would probably help the bulk of people who have typical Japanese cars that kill all the accessories while the car is starting.
Apologies for the long post, but I thought I'd share my experience with the group.
The Good:
