@jokiin someone saying class10 can have a problem with loop option at g1w-c so they are telling use class 4
do you think this is true?
If you can, buy a Kingston. I've never heard anyone complaining about using them in the G1W series. But like @jokiin said, it has to be a genuine one.@jokiin Thanks for information.
Can you give me a brand please? I will order my cam from gearbest and i want to order the micro sd with same time.
He's correct on that for the reasons stated.Do cards wear out? Was speaking to a 'professional' at my local BestBuy and he said that dashcams can be hard on cards as they are constantly erasing and reusing.....
Remember!,... I think I still have a few laying around - along with a USB drive. š±...I remember floppies used to fail (anyone else remember those?). but that was a physical mechanical process.
Do cards wear out? Was speaking to a 'professional' at my local BestBuy and he said that dashcams can be hard on cards as they are constantly erasing and reusing. I remember floppies used to fail (anyone else remember those?). but that was a physical mechanical process.
You're supposed to just let it run out, but stopping wouldn't make any difference afaik.
Strange that files would disappear, not sure what would cause this.
Oh my bad. That's strange, my G1WH has a much different firmware so it doesn't change the filenames, it just puts the files in a different folder.
I'm running G1WH-DA380-2014.11.28.03, but it probably won't be compatible if you're running a regular G1W. You can always try though.
