I've discovered the connection to the mounting base has become very loose and is causing intermitted electrical connection problems, which cause the cam to power off and them power on again when the connections is reestablished.
Physically the cam is very loose when sitting in the base. I suspect this is do to some sun exposure as I've only removed the cam from the base less than six times since installing it in mid Jan (approximately 6 weeks ago).
Only the front cam is having intermittent connectivity problem. The rear cam is physically loose but not as much as the front cam. However, both of these were very tight fitting when first installed.
I have two of these cams and I also purchased 2 more for my brother in law who has yet to install them. I've looked through the forum but it doesn't appear that anyone else has reported such a problem
Is any one else having this problem, and how have you resolved it?
Thanks in advance,
John.
Thanks in advance,
John.
