DT MI
- Oct 10, 2014
- Michigan
- More than my wife thinks I need.
I had a G1W-x camera that I wanted to try and use as a rear camera but the suction cup mount would not work because of the heater/antenna wires on the glass. I had a mirror mount that wasn't being used so I figured I'd try to adapt it somehow. Here's the step-by-step on what I did.
(You could probably do the same with a suction cup mount depending on how it's constructed but I didn't have one laying around to experiment with.)
1. This is the mirror mount that I started with:
![1-MirrorMount1.JPG 1-MirrorMount1.JPG](https://dashcamtalk.com/forum/data/attachments/13/13220-89c74e42837678fc4960c39cc6167a92.jpg?hash=icdOQoN2eP)
2. Take a cutting tool of your choice and remove most of the clamp portion:
![2-MirrorMount2.JPG 2-MirrorMount2.JPG](https://dashcamtalk.com/forum/data/attachments/13/13221-4fd4ddb3ad9f2298671785fd44d9ccc3.jpg?hash=T9Tds62fIp)
3. Find a piece of rigid plastic thick enough to retain it's shape. I used some 3/8" plexiglass I had laying around:
![3-Plexi.JPG 3-Plexi.JPG](https://dashcamtalk.com/forum/data/attachments/13/13222-79ad670da4395b3d796c7220a6d03622.jpg?hash=ea1nDaQ5Wz)
4. Sand both surfaces so adhesives have something to 'grip':
![4-PlexiSanded.JPG 4-PlexiSanded.JPG](https://dashcamtalk.com/forum/data/attachments/13/13223-f7073c34dc100a038fc3da7941ac1115.jpg?hash=9wc8NNwQCg)
5. Glue the plastic to the modified portion of the mount. I used epoxy since I knew it would work.
![5-Glued.JPG 5-Glued.JPG](https://dashcamtalk.com/forum/data/attachments/13/13224-b5e5aa06ff145941b8785b54589a5421.jpg?hash=teWqBv8UWU)
6. After the epoxy sets reassemble the mount:
![6-Assembled.JPG 6-Assembled.JPG](https://dashcamtalk.com/forum/data/attachments/13/13225-aad665ea59046cd39975a659cfd9d7c5.jpg?hash=qtZl6lkEbN)
7. I then attached some industrial strength Velcro tape to the plastic.
![7-Velcro.JPG 7-Velcro.JPG](https://dashcamtalk.com/forum/data/attachments/13/13226-95cdbfdb10ed77c66b6705acb853584b.jpg?hash=lc2_2xDtd8)
8. Attach the camera and mount in the vehicle using the other half of the Velcro on the vehicle.
![9-Camera.JPG 9-Camera.JPG](https://dashcamtalk.com/forum/data/attachments/13/13228-695f1ad1ce01094d8cc3063a8f00a126.jpg?hash=aV8a0c4BCU)
If I were to do it again I would use Scotch Dual-Lock instead of the Velcro tape as it would be more rigid when mounted. The Velcro let the camera vibrate on certain road conditions. You could also use 3M double sided high bond tape.
![8-Camera.JPG 8-Camera.JPG](https://dashcamtalk.com/forum/data/attachments/13/13227-b8bee1cae34e2682fe8abd676ec498c6.jpg?hash=uL7hyuNOJo)
