Dash cam quirk
Chas
I got a no name dash cam at a discount warehouse for 15 US bucks. It's been working amazingly well for three weeks. Then it showed a blank white screen when turned on and that was it. Two days later it started working again. Any idea what this is about?
The primary consideration when choose a dashcam should be, its working reliability, then its sharpness, then other features...
You could try a high quality SD card. Samsung Evo Select from Amazon is a great value. And the next time it goes wonky, power it with a house-type phone charger to see if the cam's PS might be the problem. But honestly for $15 you can't expect much. You don't get what you don't pay for!
I ended up formatting the card at the time and it's worked flawlessly ever since. I can't see paying upwards of $200 for a dashcam.
I had a similar issue. Most likely your micro-sd card got its file system corrupted and confused the cam. Once reformatted the cam could work again.
L Dash Cam Discussion 0
Giri43 Dash Cam Discussion 0
T Dash Cam Discussion 0
G Dash Cam Discussion 0
I Dash Cam Discussion 6
