Hi,
I'd recommend re-setting the connection. Please follow this procedure closely and in the
exact order as displayed. This is
crucial for correct connection:
1) Turn on the Camera
2) Stop it recording (press the red button on the screen)
3) Go into 'Settings' (press the button in the top left of the screen)
4) Go into 'Setup'
5) Scroll across to 'Keep User Settings'
6) Turn OFF 'Keep User Settings'
7) Go back to 'Setup' settings
8) Scroll across to 'Default Settings'
9) Select 'YES'. The camera will now reboot.
10) On your phone, please uninstall the MyNextbase Connect app. Please be aware that this will delete any saved data currently stored on the app. If you have footage saved that you require, please upload it to the Nextbase Cloud and make a note of the codes then provided. You can then download the footage to your phone at a later date, or to a computer.
11) Go into your Bluetooth settings on the phone, then delete any connections you can see to NEXTBASE
12) Go into your Wi-Fi settings on the phone, then delete any connections you can see to NEXTBASE
13) Turn off the phone and the dash camera
14) Re-start the phone and the dash camera
15) Re-install the MyNextbase Connect app on the phone
16) iPhone: Then on your iPhone, go into Settings- MyNextbase- Background Refresh Data- Ensure this is turned on. If you see 'Location' this must also be set to 'Always'.
Then go to your
MyNextbase Connect app and click on the menu in the top left of the app home screen. Select App Settings and turn on ‘Enable Low Resolution Downloads'.
16) Android: Then on your phone, go into Settings- Apps- MyNextbase- Notifications- Ensure these are set to On. Then go back one screen to Permissions and ensure these are also turned on.
Then go to your
MyNextbase Connect app and click on the menu in the top left of the app home screen. Select App Settings and turn on ‘Prefer Wi-Fi Direct Downloads’, ‘Allow analytics’ and ‘Enable Low Resolution Downloads'.
Once steps 1-16 have been followed precisely, please re-pair the phone and the Dash Cam as per the following instructions:
iPhone:
Android:
Kind regards,
Millie
Nextbase Technical Support
