- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
Check GPS performance with DataKam and compare with DashCamViewer
You can use a standard 3.5" headphone extension cable if needed.
Mirror is a bit close, try it and see. Jus my remember GPS logo goes up towards the sky. Alternatively you can take out the four screws and flip the GPS PCB upsidedown as well for a neater looking install
I have mine mounted in the upper right corner of the windshield and the camera in the center behind the mirror - no issues at all....
If I was to install this on the windshield, how far away from the camera should it be placed?...
Mounting on the windshield is the absolute last place I want to put it ... just might have to break out the cable stretcher. š I saw your video on flipping the GPS so I could do that if necessary, however, I suppose I could void my warranty and splice in a 6 inch chunk of cable and hide it behind the A pillar. I'm just starting to do the install, so I might come up with something rather than resorting to surgery.
you can plug a 3.5mm male to female extension cable in to make it longer if need be, have tested up to 1 meter extension with no noticeable signal loss
I actually think I may have a short piece of this cable in my audio junk box, I will have to try that tomorrow.
Thanks for all the suggestions everyone, very helpful. So far the short cable and the card reader are the only things I don't like about the unit, and both are easily fixed. š
Just tried Datakam and the GPS is working fine except that the map is one minute ahead of the playback screen, and putting the vehicle a couple of streets ahead. I guess that it needs a time offset of one minute applying, if I can figure out how to do that.
Would that one minute disparity cause no GPS input on Dashcam Viewer?
Try the new version of DashCamViewer that was just released today:
http://dashcamviewer.com/2015/05/02/dashcam-viewer-v1-7-4-released-for-mac-and-windows/
this is where I put mine, see if you can spot it.Mounting on the windshield is the absolute last place I want to put it ...
it wasn't here half hour ago, was only posted 10 minutes ago, but I posted this in the where did you mount your cam thread a few weeks ago.Oh, I like that! Wish I would have seen your post 1/2 hr ago ...
