BataviaJim
What is the trick to remove the Mini-2 from the adhesive windshield mount? Mine is really tight. I removed it once before mounting and I had to pull very hard to get it out, then push as hard to get it back in.
I tried to remove it after I had mounted it, and the mount pulled away from the windshield. (I had followed all instructions to mount it.) So now I don't know if the mount will hold to the windshield, and if it does, how I can remove the cam without pulling off the mount.
I found nothing in the manual about this. A search of this forum turned up a suggestion to pull it to the right but that didn't work -- that's when the adhesive mount came off.
I'd appreciate any suggestions. Thanks.
