AS87
- Apr 19, 2016
- India
- Viofo A229 Duo
The initial plan was to get the Viofo A129 Pro Duo 4K but thanks to this forum, I knew that there is a successor coming in the form of the A229 series so I decided to wait for a bit for all the initial niggles are worked up and then I can get one. Finally decided to bite the bullet and get the Viofo A229 Duo with the hardwiring kit and CPL filter set. Prior to this dashcam, I used the Mini 0806, Viofo A119S and DDPai Mini.
The Setup: Viofo A229 Duo + Viofo HK4 hardwiring kit + Viofo CPL Filter + SanDisk Extreme Pro (128GB)
A229 Duo - Package Contents
The Package contents are:
Viofo HK4 Contents (L to R - The box; 2 pairs of Low-profile MINI ATM fuse taps with 5A fuses included; Hardwiring kit & HK4 User manual)
Viofo CPL Filter (For the front camera)
Front Camera - GPS mount (USB-C Port which not only powers the camera but also records the GPS coordinates + speed data)
5-pin connection
Front Camera - Drivers side view
Front camera - Windshield side view
Front camera - Side view of the ports and connections
Rear camera
- Trim panel removal tool
- Viofo's SD card reader
- Rear Camera unit
- Main Front camera unit
- Spare 3M sticker pad for the rear camera
- Spare 3M sticker pad for the front camera
- Coaxial cable - To connect the front camera and rear camera. 6m long thinner in dia for easy and a cleaner install
- USB-C cable to connect to the car's 12V socket - IF hardwiring is not being done.
- Viofo's 12V USB power adaptor
- USB-A to USB-C cable to connect the front camera to the computer to transfer files and/or upgrade the firmware
- A229 Duo User manual
- Warranty policy card with installation details
- Initialization instructions are to be followed BEFORE the installation is done to verify whether both cameras are working as intended or not
- Windshield static stickers (x 2) were provided for a cleaner installation. This is to avoid any sticker residue on the windshield and if one wants to change the position of the camera post the installation.
5-pin connection
Rear camera
