The newest EZ firmware is here. However this also has the dreaded WDR auto applied issue that has degraded TF2+P night time quality. So while the firmware is different the argument looks like it will be the same.do the discussion on tf2+ firmware apply to my tf2 ez as well? I have 2 vico tf2 ez.
Thanks!
I believe the the TF2+P has settings the EZ does not have like being able to select 140 or 160 FOV so you would defiantly not want to mess them up.But firmware to TF2 and TF2+ looks different so don't mix up it.
Yeap, I have TF2 EZ with 5.0 firmware and I don't want to upgrade to 5.2 because of removing WDR (but bitrate was raised to 13mbit on 5.2).
I can give you older firmware and you can do downgrade:
http://vicovation.com/uploads/Vico_2013842931.zip
