DR500GW-HD, date is 3 days out of whack, how to fix??
wozzzzza
this crap of a thing I made a mistake of getting a couple of years ago has really got me pissed off, its got a life span far less than I had anticipated, the last file always corrupts when ever power is shut off, now the time is always out, showing 3 days ago today.
whats the issue with the time?? why is it 3 days out?? how to fix??
cant wait to get rid of this ****ty thing.
Hillbilly
Sunshine Coast
DR750s x2 DR450 x2
Sounds like the capacitor has failed and not holding a charge.
Similar to what my 400 did a while ago If you don't use it for a while it could do that similar to a car that isn't used for a while.
Mine is over 2 years old and not having any trouble despite being almost too hot to hold on a few days last month is still working fine.
The 400 has had the Lipo battery replaced and is also working Ok now.
Has been instructions on how to replace the cap on here somewhere.
Shouldn't be a big job provided you can get the part.
wozzzzza
wozzzzza
thought it might be. oh well, hoping jokiin will have his cam ready soon so I can ditch this crap.
jokiin
Too many ¯\_(ツ)_/¯
apologies for the delay which is causing you to live with that, taking longer than I want also
alexsoll
Retailer
Minsk
Belarus
Street Guardian, BlackVue, Thinkware
Translate there is no time. After one of the following methods everything will be OK
Не ловит спутники, не отображает скорость, неверная дата и т.д., пробуем варианты ниже:
Само собой, перед дальнейшими действиями,
должен быть выставлен в настройках программы часовой пояс, соответствующий вашему региону,
а поиск спутников необходимо вести под открытым небом
(НЕ на балконе, в квартире у окна и т.д.).
1. Скачиваем эту программу
2. Карта памяти в компе (содержимое в папках System и Record очищено), запускаем вышеуказанную прогу
указываем путь к карте памяти и жмем Save ( синхронизируется время с компом и переносится на карту)
3. Быстро карту в рег и запускаем. Желательно подождать коннекта со спутниками и дать поработать пару минут.
4. Карту в комп, чистим System и Record
5. Карту в рег и запускаем его.
6. Всё.
1. В меню программы blackvue выключить отображение скорости (по умолчанию стоит км/ч), сохранить настройки.
2. Выключить регистратор
3. Снова включить регистратор, войти в меню программы и включить отображение км/ч.
4. Перезагружаем регистратор.
Копируйте с карты памяти на комп папку BlackVue, затем форматируйте карту, далее пустую карту вставляем в регистратор, произойдет инициализация (с NAND-памяти регистратора данные перенесутся на карту памяти), извлекаем карту, форматируем её по-новой, закидываем обратно на карту ранее скопированную папку BlackVue ( находящиеся в ней папки Record и System должны быть пустые), вставляем в рег, включаем (само собой не в квартире, а на улице и т.п.). Ждем пару минут (может чуть меньше, может чуть дольше).
1. Разбираем рег.
2. Отсоединяем фишку модуля GPS от платы.
3. Выпаиваем батарею/аккум (MS621F) полностью или одну ногу.
4. Возвращаем на место фишку GPS-модуля (с отпаянной батареей), включаем рег (собирать не обязательно, можно и в помещении, коннект со спутниками не нужен, SD-карту перед включением желательно форматировать). Даем поработать примерно минуту-две. Выключаем.
5. Заново пайкой соединяем батарею и не собирая регистратор, включаем его (карту снова желательно перед включением форматнуть и выйти в зону уверенного приема спутников, балкон/улица/открытое пространство), запускаем на реге wi-fi, подключаемся с компа или иного гаджета по LIVE, ждем появления отображения скорости (у меня обычно спутники цепляет и начинает отображать скорость через несколько минут ожидания)
6. Собираем рег в обратной последовательности, опять-таки не грех форматнуть карту лишний раз, включаем, ожидаем (может длиться несколько минут)... и радуемся работоспособности GPS.
