mitch musni
- Jun 10, 2016
Hi, everyone.
I just purchased and received the DR650GW-2CH + Cellink B last week. Finally hooked it all up yesterday, both front and rear cams. I am enjoying it--although hopefully it does not fail in the summer heat as I plan to leave the cams in the car during my work hours.
I am using the stock adhesives that they come with. The front cam is against the front windshield, but the rear cam is seated on a flat plastic material on the ceiling of the car. I have attached a picture of (what I believe to be) the same material but it is used on the interior passenger side door. Unfortunately, I cannot produce the picture of where I installed the rear cam, but my issue is that it keeps falling off. I'm worried the front will fall off, too. Is anyone aware (or can confirm) if they have had any issues with their adhesives failing against plastic surfaces? Are there any recommendations for stronger adhesives that will not damage the surface?
FYI: I drive a Hyundai Veloster...if you've driven this car before or have seen the rear interior in detail, you know that it's a bit difficult to install it on the rear ceiling window.
Any thoughts? Thank you!
