Wargoose
- Sep 12, 2014
- Ontario
- Canada
- BlackVue DR750S-2CH
I recently upgraded my DR550GW-2CH to a DR750S-2CH and was a bit disappointed to see that the slight focus issue that plagued some of the old 500 and 600 series cameras was still present, especially on Blackvue's new flagship. Since I had fixed this on my 550 easily enough, I did the same with the 750. Removed the trim ring around the lens with my fingernail (it will pop off) and then adjusted the lens. The lens was not glued in position as some older cameras have exhibited, nor did I need pliers to rotate it - finger strength was enough. It needed to be rotated nearly 5mm clockwise (as you face the lens) before I was satisfied with the image.
Aside from that, I'm pretty happy with it. The rear is also a bit fuzzy, but the 1080p is still much better than the old 720p. I'm also running a CPL filter - you can just spot the edges at the corners of the video due to the larger lens the 750 uses.
