DR750X-3CH DMS Plus and DR750X-3CH TRUCK Plus Now Available
BlackVue_Pittasoft
South Korea
Korea, Republic Of
Following last month’s launch of the DR750X-3CH Plus, two new models have just joined the triple-channel BlackVue dash cam lineup.
The DR750X-3CH TRUCK Plus is similar to the DR750X-3CH Plus but with a waterproof external infrared rear camera instead of the regular rear camera.
The DR750X-3CH DMS Plus, on the other hand, introduces a new driver-monitoring camera designed to detects drowsy or distracted driving and alert the driver accordingly.
DR750X-3CH TRUCK Plus​
The DR750X-3CH TRUCK Plus simultaneously records the front, rear and interior of your vehicle. Each of the three cameras is equipped with a Sony CMOS sensor (STARVIS™ for front and rear). The waterproof infrared rear camera connects to the front unit via a 15m (49ft) video cable. The interior camera connects to main/front camera via micro USB.
  • Front Cam: 2.1 megapixels STARVIS™ sensor / Full HD (1920×1080 @60FPS) / View angle: 139 degrees.
  • Rear Cam (coaxial): 2.1 megapixels STARVIS™ sensor / Full HD (1920×1080 @30FPS) / View angle: 116 degrees.
  • Interior Cam (micro USB): 1.27 megapixels Sony CMOS sensor with infrared LEDs / Full HD (1280×720 @30FPS) / View angle: 119 degrees.
If you are curious about how much recording time you will get with these new models, check our video quality settings and recording time table on this page.
DR750X-3CH DMS Plus​
The DR750X-3CH DMS Plus is a triple-channel Cloud dash cam with a special-purpose driver-monitoring camera (DMC100). The “DMS” in the model name stands for Driver-Monitoring System, in reference to the function of the DMC100.
DR750X-3CH DMS Plus
  • Driver Monitoring Cam (micro USB): 1 megapixel CMOS Sensor / HD (1280×720 @10FPS) / View angle: 54 degrees.
The infrared Driver-Monitoring Camera (DM100) is designed to improve driver’s safety by helping prevent risky driving behaviors. The DMC100 monitors the driver at all times. Its algorithm can detect statuses such as:
  • Distracted driving
  • Drowsy driving
  • Driver detected/undetected
As soon as a potentially dangerous situation is detected, the DMC100 emits a beep to alert the driver and triggers push notifications if connected to the Cloud.
Additionally, Fleet Plan users can check detailed reports based on the data collected, provided the dash cam is connected to the Cloud.
driver-monitoring-camera-drowsiness-distracted-driving-alerts
Notes about the DMC100:
  • The DMC100 is not designed to record the whole interior of the vehicle. It is designed to focus solely on the driver and analyze and detect drowsiness or distraction in real time.
  • Requires powering separately: the DMC100 comes with a hardwiring cable to power it (the USB cable is only used for data transmission to the dash cam main unit). However, it will turn off when ignition is turned off.
  • Not active in Parking Mode: even if you managed to power the DMC100 while parked, keep in mind that it does not record in Parking Mode. Only the front and rear cameras do.
Native Parking Mode​
With their built-in voltage monitor, you can hardwire DR750X-3CH Plus models to your vehicle’s fuse panel to use Parking Mode. As soon as you turn off your vehicle’s ignition, the dash cam will go into Parking Mode, protecting your car while you are away. There are two Parking Mode “modes”: Time Lapse + Impact and Motion + Impact.
In Time Lapse + Impact mode, your dashcam records a time lapse video and in case of impact detected by the accelerometer, the camera records a full audio/video segment including the few seconds leading up to the impact.
In Motion + Impact, one-minute recordings are triggered by visual movements detected by the dash cam’s cameras, as well as the impacts.
Wondering which mode you should choose?
  • Parked in a quiet area with little movement, traffic? Or you absolutely need audio (no audio in Time Lapse clips): choose Motion + Impact detection.
  • Parked in a busy area (where the camera would keep recording motion-detection videos) or just want to be able to record for hours without overwriting older footage: pick Time Lapse mode.
Note: the DMC100 (Driver-Monitoring Camera) in the DR750X-3CH DMS Plus does not record in Parking Mode.
Cloud Connectivity​
Both models are Cloud compatible, meaning you can use the BlackVue Connectivity Module (CM100LTE) or a third-party mobile Wi-Fi hotspot to connect your dash cam to BlackVue Cloud. You can check the view from any of the three cameras from anywhere with the BlackVue app.
However, with BlackVue Cloud it is your dash cam’s Parking Mode that really shines. When an impact is detected, not only do you get an instant Push Notification but with Live Event Upload, the video of the impact—including the pre-impact buffer—starts saving straight to the Cloud as it happens. That means even if the dash cam gets disconnected halfway through the video clip, the footage up until disconnection is safe in the Cloud.
FAQs​
Are the power and video cables compatible with past models?​
Power cords: same 3-wire type cables (cigarette lighter power adapter or hardwiring cable) for native Parking Mode support as DR900X, DR900X Plus, DR750X, DR750X Plus models. Not compatible with prior models (DR900S, DR750S, DR650S, etc.).
Rear camera coaxial video cable: compatible with all past models using a coaxial video cable.
In short, if you have a DR900X Series or DR750X Series BlackVue, you can keep both power and video cables in your vehicle and just add the USB cable for the interior-facing camera.
If you have any prior model, you could keep the coaxial video cable installed but will have to replace the power cable.
Can I turn a Single or Dual-Channel DR750X Plus into a DR750X-3CH Plus?​
No. While bearing resemblance with DR750X-1CH Plus and DR750X-2CH Plus models, the DR750X-3CH Plus Series use a different firmware.
This means that while you can choose to use only the front camera of your 3CH model, you cannot upgrade the 1CH or 2CH version to 3CH.
How to connect the BlackVue Connectivity Module (CM100LTE) if the interior camera already uses the USB port?​
The DR750X-3CH Plus includes a USB Hub connector (1 micros USB port in, 2 micro USB ports out). This allows you to connect both the interior camera and the BlackVue Connectivity Module (CM100LTE).
Why not integrate the interior-facing camera in the front unit?​
Good question! It is all about discretion and flexibility of installation. The ideal spot for the front camera is somewhere in the upper-middle part of the windshield, hidden behind the rear-view mirror. Therefore, an interior facing camera stuck on the front camera would have its view obscured by the rear-view mirror. In order to capture the interior, you would then have to place the camera in a more obvious location, potentially obstructing your field of view. That’s why we find that having the interior-facing camera as separate units gives more flexibility to do a stealthy installation.
Thank you for the super-detailed description of the DR750X-3CH DMS Plus.
[Power & Video Cable Compatibility with DR650GW-2CH]
Under FAQs, I was particularly interested in power & video cable compatibility with my 9-year-old dying DR650GW-2CH. Both power and rear camera coaxial video cable are BlackVue OEM cables. So, except for the USB cable that must run from the front camera to the DMS module, the DR750X-3CH DMS Plus should function with these existing cables. Am I correct?
[Front Camera Mounting Bracket Compatibility with DR650GW-2CH]
However, would the front camera of the DR750X-3CH DMS Plus slide into the existing bracket for the front camera of the DR650GW-2CH? I don't believe the rear camera of the DR650GW-2CH has a bracket. Rather, I believe it is a stand-alone module with a coaxial port into which you plug the coaxial video cable. And, I assume that the rear camera of the DR750X-3CH DMS Plus has the same system. Am I correct?
Thanks for the information!!
