DR970X Plus Series 2 Shutdown/Restart FW 2.005
DCS Australia
Sydney
Viofo A329S, Vugera SV2 Pro, Lexus DRT-100L
Hi everyone,
Has anyone (with a DR970X Plus Series 2) had the following issues
1) intermittent shut down ("Powering Down") followed by a restart within 10 sec
2) delayed restart after max. 10 min. while driving
it's approx 24~25 degree Celsius here in Australia, not directly under sunlight.
Diagnosing for patterns, if any. Seems like an overheating scenario, but too early to speculate.
Haven't had this issue with the DR970X Plus Series 1.
Thanks in advance.
P.S. HDR ON, Not Extreme Mode
Hi everyone,
Thanks in advance.
Hi @DCS Australia,
I too am experiencing the exact issues you are facing since upgrading to the latest firmware (previous to v.2.005_2025.10.01). I never faced these issues before the recent updates.
The cam seems to run extremely hot at times and randomly shuts down, rendering my SanDisk High Endurance SD (512GB) toast. SD card not detectable when inserted into laptop card reader. Recovery software did surprisingly work initially and I managed to copy footage over. Now it seems like I need to reformat and try again. I feel it's destroyed the SD card, however I will need to verify in a few days.
I only have a DR970X Plus 2-channel, but I have not experienced that behavior with v2.005 installed. So, my experience is the same as the OP's with the older dash camera model and firmware.
I just updated that dash camera to v2.006 which was officially released on 01-Oct-2025. I just states "Minor bug fix" in it's change log.
Hi @DCS Australia,
When did you first start using the SanDisk HIGH Endurance micro-SD? It's not reliable and deteriorates quite fast especially with 4K operating with HDR at high temperatures.
I've got a replacement unit since and so far OK. However the HDR is a joke and nothing more than ISP with grainy footage. I will likely move over to the ELITE 8 in order to compare it to the A229 Plus. 🙂
Hi everyone,
Thanks in advance.
Yes. I have series 1 and same thing since update in Australia
It's weird as series 1 now gets an HDR update when the core processor (Ambarella) couldn't technically support it at the first place.
HDR raises the operating temperature by a degree or two, which can result unexpected operating issues. Let's see!
Hi @DCS Australia,
Use Sandisk MAX endurance, High Endurance is not good. Or Sandisk Extreme also ok.
Blackvue australia told me they dont recommend samsung pro endurance plus or sandisk anymore
What SD card you using? Blackvue australia just told me they dont recommend the samsung pro endurance sandisk anymore due to heat related issues
According to blackue Australia samsung pro plus is the only third party SD card now they recommend as of there latest testing
Hi everyone,
Thanks in advance.
Try H264 which runs cooler IMO. My Blackvue runs so much hotter the my 229 pro
