D
Deleted member 37895
Guest
I've been experimenting with a 16mm lens Mobius camera and a standard lens unit for traffic logging, and have decided to combine both the telephoto and wide angle. Basically the narrow angle camera is the main one, but the standard lens Mobius acts as a backup if it's aimed improperly. I got the Mobius with 16mm lens pre installed from BuyMobius.com and the normal one from Spy Tec. I did also order a 6mm lens to try from Mobius-ActionCam.com and will probably recieve it this week. I got this aluminum housing from the Eightwood store on Amazon. It's specifed as 4.33" x 3.74" x 2.17" and has a top panel and screw on side panels which I didn't use. The top panel slides freely but I put some vinyl tape on the edges so it stays in place when it's slid into the slots. Holding the Mobius cradles in place is 3M Dual Lock which is way better than Velcro because it locks in place without play.
