You have just updated the firmware successfully! This proves that the firmware and camera are intact and working correctly.
There must be a problem with either your USB cable or the USB hub/pc or your battery is bad. OR, if the camera doesn't record with external power the lens module cable could be dislodged or even broken
There is a very, very remote chance that the USB circuitry in the camera is not working, but I have never heard of a USB hardware failure in the Mobius so far.
Hi isoprop, may be you could help?
I break my lens on a bad landing, i plan to change it, but i can no more connect the mobius to the PC... the cam work, i can record, i've just update the FW as you explained here but PC still not recognise my mobius... i've just received the new lens (without ribbon) but not change it for the moment. do you have an idea??
PC do not recognise also the card in the mobius as an usb card...
An other thing, my batterie is dead, but that was not a pb because a used the mobius for FPV with electrical feed from the immersion RC video transmitter.
The PC does not charge anymor the batterie (no green led).
Thanks for help.
