RickReichert
- May 10, 2013
- Oregon
- DVR 207 (not GS)
I've had the DVR-207 since May 2013, and it has never worked right. It records for a while, then either hangs (black screen) or keeps recording but creates gibberish file names. To be able to troubleshoot here at home rather than in the car, I built up a 12-volt source using an old ATX computer power supply and a female 12-volt socket with in-line fuse. I suspect the problem is with the Transcend 32gb class 10 memory card. Today I tried an old 2gb SanDisk Ultra II Class 4 card and it seems to be working. I haven't checked for gaps between 2-minute segments, but at least the DVR-207 hasn't hung and overwrites the memory when it fills up, as it should. I sent an email today to estore009 asking to return the 32gb Transcend card for replacement with something that works. I'll post again when I hear back from them. I'll also try other SD cards to see if they will work.
