EricSan
- Dec 28, 2023
- Central PA
- United States
If I'm not mistaken, the parking/driving mode in Vantrue is controlled by contacts: TX1- and TX2-
Ha, the more I look around, the more conflict I find with wire color conventions and which pin those wires actually connect to. A few amazon reviews of USB-C pigtail wires even indicate that the wiring was not done properly because the USB-C connector is not reversible. Another cable diagram shows a yellow wire for CC1 and a blue wire for CC2, but these pins are the same when you reverse the cable... This is infuriating! 😡
Hmmm... the first thing that I can think of is to check the wiring for loose wires. My Vantrue regulator definitely shuts down at the corresponding voltage settings for the switch, though it is not immediate, it takes a minute or two to shut down once the voltage threshold is reached. There is a time-delay function built in - very clever design!Maybe something else is going on with the hardwire
i set cut-off at 11.7, but it displays that the batteries are at 11.9
cos i've been using the camera for a month now and only the last few days will it shut down at some point
It is possible that the batter voltage is "recovering" a little after the shutoff happens, but I'd expect this is with a larger current draw than a mere 5w.
