Event recording
Verdoni
France
Although the Dashcam 7950 manual says that Event Recording happens when impact takes place, my dashcam records a video in the micro SD at moments when no special event occur; Any suggestion this? Thank you
William Richardson
Burton, NB, Canada
Lukas LK 7950 WD
There are two possibilities. First is the sensitivity level is to high. However you usually hear a chime from your dashcam when you have triggered an event log. If this is not the case you could simply be seeing a non event log that will be overwritten when space runs out where the event logs will not until a format happens. Other then that I don't know. I really don't pay much attention as I know mine seems to be working fine.
V
Verdoni
France
Thank you, I have lowered the sensitivity, it should solve the problem.
Berserk80 LK-7950 14
