The playback from the memory card is absolutely lousy, I switched the cards still very bad. Any suggestions?
Thank you for your response. 1st card I used was the Thinkware 32GB card that came with the F800 Pro. 2ND card I used was 128GB HD+ card I used in another dash cam with beautiful playback. But on the 800 lousy playback. Also the 800 doesn't record continuously.What type of card are you using, and what are the specifications? Is it less than a Class 10? Is the source genuine? I once bought a 64GB Samsung MicroSD that turned out to be a 16GB MicroSD and I suspect it was a forgery! [emoji15]
Sent from my iPhone using Tapatalk Pro
Hello There, If you are experiencing an issue with video quality of playback please reach out to us at support@thinkware.com. The F800 Dash Cam should be recording continuously in 1 minute segments with no gaps, when in Continuous Mode.Thank you for your response. 1st card I used was the Thinkware 32GB card that came with the F800 Pro. 2ND card I used was 128GB HD+ card I used in another dash cam with beautiful playback. But on the 800 lousy playback. Also the 800 doesn't record continuously.
