MikeHawk
Seems like the rear camera on the latest A329 uses the same 2.8mm coaxial cable as our cameras
the A139 Pro is a 3ch camera which supports 4K30 + 1080p + 1080p
The A329 is 2ch which supports 4K60 + 2K30
Assuming the A329 is set to 4K24, the bandwidth requirement would be relatively similar between those two configurations, (around 3% higher for the A329, which is very little)
Is this technically possible like the numbers show, or is there something I'm missing? Could this be considered by the Viofo team?
It would be a nice upgrade as the newer 2k30 cam is much superior to the 1080p one found on the A139 Pro, both in resolution and dynamic range
Cheers
Cheers
