File will not play
RGB47
When I save a segment of a file and try to play it with Quicktime, it will not play. I get the message: Error 2002: a bad public movie atom was found in the movie (fragment of xxxx filename. mov). When I try to play it using Windows Media Player, Media Player freezes. When I bring it up in iTunes it plays just fine, as it does in Registrator.
Any ideas on this?
Thanks.
download k-lite codec and install it.
You said segment of a file.
How did you create the segment?
I use daum potplayer. It plays everything.
Created it in Registrator ... as I said, they will play fine in Registrator and iTunes, but freezes up in Windows Media Player and they give the error message as above when trying to play with Quicktime. Everyone has Quicktime and wanted to send a few segments to a couple of friends.
Download Daum Potplayer for playback.
Also, registrator viewer can't handle some files correctly.
I use Free Video Cutter joiner and other programs for cutting.
Registrator viewer only for NT96650 based cameras.
Actually Registrator Viewer is predominantly for the Ambarella platform, there's less support for some of the other solutions
Maybe but I had troubles with it opening G90 files but never any problem with any of the Novatek based cameras.
