wozzzzza
- Mar 12, 2013
- Australia
after not having the car for ages, finally got it and have time to start installing it.
PART 1 of the install, the left hand camera
Here is the outside of the vehicle.
![IMG_5923.JPG IMG_5923.JPG](https://dashcamtalk.com/forum/data/attachments/53/53905-6240d4a3fbc5e0f8afc3b6b4751cfd56.jpg?hash=YkDUo_vF4P)
here is the inside of the rear door, full of the kids crap
![IMG_5921.JPG IMG_5921.JPG](https://dashcamtalk.com/forum/data/attachments/53/53906-a6f3bc2f25b796c2ebba73896bc38426.jpg?hash=pvO8LyW3ls)
this is where i am going to run the camera cable
![IMG_5924.JPG IMG_5924.JPG](https://dashcamtalk.com/forum/data/attachments/53/53907-59f015510b647e7c1959f6ce1414cca6.jpg?hash=WfAVUQtkfn)
here is the inside of the door with the trim removed
![IMG_5925.JPG IMG_5925.JPG](https://dashcamtalk.com/forum/data/attachments/53/53908-19634f2dc77211937e46b53f7db5907a.jpg?hash=GWNPLcdyEZ)
this is the hole i drilled in the rear door for the cable.
![IMG_5926.JPG IMG_5926.JPG](https://dashcamtalk.com/forum/data/attachments/53/53909-84481e04b4fc4c73490e82071cc8ace9.jpg?hash=hEgeBLT8TH)
this is the rubber cable conduit i kindly got from Jokiin luckily, wasn't easy to source. i had to drill holes in the door and the b pillar as the OEM rubber conduit you see there is a plug style and it is all filled up and nowhere to drill a hole through it so had to put a second one in, didn't like doing it but had to do it, only way to get an extra cable into the door.
![IMG_5927.JPG IMG_5927.JPG](https://dashcamtalk.com/forum/data/attachments/53/53910-c399967239bec56133b841f4f8ed1f4a.jpg?hash=w5mWcjm-xW)
![IMG_5928.JPG IMG_5928.JPG](https://dashcamtalk.com/forum/data/attachments/53/53911-c58ffe2dc52bfe95459e149f14f1ab4f.jpg?hash=xY_-LcUr_p)
i had to pull the speaker out of the door to gain access to the inside of the door. i ran the camera cable through the rubber conduit from the door side first then through the B pillar. the camera end of the cable i routed up through the factory hole in the door and out so i could put it into the door trim.
![IMG_5929.JPG IMG_5929.JPG](https://dashcamtalk.com/forum/data/attachments/53/53912-5f1125808f681e8eb2c2bb689ded5dfa.jpg?hash=XxElgI9oHo)
this model CX-9 has a pull up blind on the back door windows, not sure if all do but this one is top of the range model. so i had to remove the blind from the inside of the door trim and drill a hole in the end of it and elongate the hole so the USB end would fit through it.
![IMG_5930.JPG IMG_5930.JPG](https://dashcamtalk.com/forum/data/attachments/53/53913-19736575d2ed1bf3bc8299a3957be914.jpg?hash=GXNlddLtG_)
i put the blind back onto the door trim, left plenty slack in the camera cable for manoeuvring the door trim and put the door trim back on and let a bit of cable hanging out to attach the camera to.
i pulled up the blind and it fits perfectly the camera in that location. will affix camera in part 2.
![IMG_5931.JPG IMG_5931.JPG](https://dashcamtalk.com/forum/data/attachments/53/53914-afb1a606d34c4c27b2917b203264344c.jpg?hash=r7GmBtNMTC)
