kantonburg
- Jul 19, 2019
- VA
- Viofo A119 V3
Got a Mini 2 for our '23 Honda Civic Sport. I tested my fuses twice to see what Switched & Constant would be. I went out earlier and wanted to test the taps and make sure everything was ok before I ran everything. In the diagram below I'm using 19 for constant and 42 for switched. My thought here was the wires would be going the same direction for a neater install.
So I plugged up everything and used a temporary ground. The dash cam booted up fine when the car started. When I turn the car off it says "parking mode". But when I unplug the dash cam and the car is off I don't get anything. I "thought" it was supposed to come on with constant power. Here is my diagram I labeled. It mentioned parking mode when I turned the car off when it was set to time lapse. I've since changed it to low bit rate mode, but haven't went back out.
Thanks everyone for advice.
edit: I am using the latest firmware. 20231116
![1703443908601.png 1703443908601.png](https://dashcamtalk.com/forum/data/attachments/69/69692-f3e950c42f87b4f5bd7a689a7ee1f9e2.jpg)
