Flickering & memory error
Frenky Tan
Malaysia
Viofo A129 Duo, 119 Pro, 119S, Yi DashCam
Hi guys I'm installing this model for rear/back of my ioniq hybrid. I extended the usb cable twice with 1.5 meters each. And the screen flickering and it said memory error. But if i plug with USB power adapter and the shortest USB provided from the package is working fine. It seem the current draw electric somehow maybe not enough or something else? I did tried using original USB cigarette lighter provided 3.1A, innergie 2.1A, and yi 1A. All of them doesn't work. How to fix this issue?
That's a brand new model car not available here yet.
Install a 12 volt dc outlet nearer the camera then use the supplied USB adapter. If you want camera to turn on/off with car ignition, use a "switched on supply". If always "ON" use a "unswitched", always on supply.
Just curious. How much does the car cost in RM.
Thanks I managed to pull the USB from behind into front USB seat, car cost expensive, hundred thousand plus.
