I am trying to hardwire a Nextbase 322 GW to the fuse box of my car (2019 Ford Focus) but the fuse lead(s) supplied with the hardwire kit I bought don't fit into any of the fuse slots in the car.
The hardwire kit I got is this one: https://www.halfords.ie/technology/dash-cam-accessories/nextbase-dash-cam-hardwire-kit-159302.html
There are two fuse cables with the kit, one large and one small. I am unable to fit the smaller one into a 10 amp fuse slot. The first pic shows the fuse cable from the kit (coloured black) with the 10 amp fuse from the slot I am trying to put it into. As you can see the fuse cable is too big. I have two other pics with the measurements of the fuse.
There is another fuse in the fuse box (a 30 amp one; called the circuit-breaker) and I am unable to get the large cable fuse into that. All the other fuses seems to be three blades and the fuse cables that came with the kit have two blades.
So the small 10 amp fuse (it is marked no. 3 in the fuse box) seems to be my only hope.
I think I need a different fuse cable; a micro fuse tap. I have seen a this one online but I can't tell from the photo if it is the correct size;
www.connect-consumables.co.uk
Can anybody advise me? Thanks
![www.connect-consumables.co.uk](/forum/proxy.php?image=https%3A%2F%2Fwww.connect-consumables.co.uk%2Fitems%2Flarge%2F37189.jpg&hash=41d67fc83fa58194ebab7037b8c41f3e&return_error=1)
Connect Consumables 37189 Add-a-Circuit Blade Fuse Holder for Micro 2 Blade Fuse 1pc Replaces OEM
12v Add-a-circuit fuse holder to allow a fused power source to be taken from an existing position.
