Front camera not visible/recording
Being the cool guy / company is where it is at, CUZ so many dont even try, or almost worse just fake it.
The ribbon cables seem to often be the culprit, it have also often happened with the one to the sensor PCB or the LCD screen, i can not say if it have been a design flaw or maybe trying to get by with a cable a little shorter than it aught to have been.
At least for cables not seeing a lot of movement like LCD it is a bit weird CUZ from my experience the little sockets the cable go into are gripping it just fine.
Your average smart phone will also have quite a few of these flat cables that connect this and that inside them, no idea if it is also failing there as i have absolutely 0 interest in those devises.
For something like this.
With what is a older model, that granted some people might have gotten recently.
Viofo should offer a complete video guide in how to take system apart and replace the broken component ( ribbon cable ) which viofo should mail people for free.
This i personally feel would be very good towards people that might be out of warranty by now, then they or someone they know with DIY skills should be able to repair the camera.
I am firmly against the buy and throw out culture, i run all my things until they die, i do not get a new phone if there is a new model like some people will do.
It would be nice if viofo adopted that same idea of repair dont throw out.
At least with easy things like if a ribbon cable are busted, i can understand viofo not doing so with more complex things that most " regular" people do not have the skill or tools to repair anyway.
Of course i know that viofo could not carry every single part for their many systems in a spare part system, but some things i assume you could carry with little expense, or maybe just go buy a few now and then as needed to be able to provide this service.
Of course viofo would then loose a sale possible if people choose to repair, but in my book viofo would also gain respect for adopting the repair ideology.
I tested the T130 back in the day and ran it for a little more than a year, and i had no issues with it at all, tested 10 or so different memory cards in it, but also pulled it now and then to look at footage.
T130 is my fourth Viofo dashcam over the years. But if this issue is not properly resolved I will definitely be switching to another brand. Over the years I have "advertised" the brand effectively and often, turning a blind eye to some flaws. But this situation is definitely the last straw.
So I was not spared this problem.
The front camera stopped working.
The camera is exactly 3 years old.
I read above that it could be a ribbon train, but I doubt that's the case because I haven't turned the camera in 3 years.
No camera is shown in the application, only on the memory card you can see which cameras are recording.
I disassembled the camera to check the contacts, everything was fine, changed the firmware, reset it to factory settings, but nothing helped.
I created a ticket in Viofo support, sent them the faulty camera ($12), paid $30 for service and they sent me a new T130 DVR, the total cost was $42, I think it's better than just throwing it in the trash.
Absolutely the same thing happened to me. It's definitely a camera hardware issue. But in their minds it's a card issue. Waste of time...
Add me to the list times two. I bought two T130s and installed one in the front and one in the back. I used the "rear" cameras as side view cameras.
I ordered them both on August 1, 2023 and they both failed (in slightly different ways - see details below) sometime before May 17, 2026. Possibly probably much earlier than that.
I suppose *I* should check videos at least monthly but a) doing that probably would have caused the failure of the ribbon cable sooner and b) why should I expect there would be a manufacturing defect that severely limits the lifespan of [what was at the time] a high end product? And why should *I* have to be the last line of defense against their product and act as their QC department? AND ANOTHER THING... just kidding. I'm not as angry as I probably sound but I have had time to cool down between the time when I found out about the failures and when I found this thread. Not angry but certainly very frustrated.
Here's how the two cameras failed slightly differently:
T130 mounted on the FRONT windshield​
  • "Front" (main) camera stopped saving any videos at all.
  • Interior and rear cameras recorded as expected.
  • When connected to the android app via WiFi, would not switch cameras in the app.
T130 mounted on the REAR windshield​
  • "Front" (main) camera saved videos which were entirely black except they did include GPS/timestamp info.
  • When connected to the android app via WiFi, will switch cameras in the app but the "front" camera was entirely black except for the GPS/timestamp info.
Hey Viofo support:
Maybe going forward the software should detect when more than n% of the pixels are black and do not change for part or all of the x minute loop - with the possible exception of parking mode. Then have a voice say something like "Front camera failure detected."
Wouldn't it be marvelous if that feature exists in newer models?
Hey Viofo support:
Did you contact support at https://support.viofo.com/support/tickets/new and describe all the issues with your models?
What did they say?
I know several users who had the same problems with the T130; they received help from Viofo support and were satisfied.
Hey Viofo support:
Sorry for the unexpected issue. I will send you a PM to solve the issue. Please update the firmware and reset the camera by R hole at the same time.
Hey Viofo support:
Sorry to hear about your device failure, certainly not you would expect or want from something of that age. I don't check my footage monthly but certainly expect my dashcams to be set-and-forget devices.
I believe DDPAI is the only manufacturer I've seen to date, implement visual notifications when a cable is faulty / plugged-in-incorrectly etc. Others give audio prompts, but certainly some good ideas you put forward there.
Hopefully there is a speedy and satisfactory resolution to your problems soon.
What did they say?
No, but as seen above, VIOFO-Support did PM me and I have sent them the requested information.
UNFORTUNATELY, having updated the firmware on both cameras, the problem is far WORSE. Where before I only lost functionality on the main camera, NOW I have lost functionality of the front AND rear cameras - ON BOTH UNITS. 😔😔😔
I was
thinking I would use these defective T130s just to monitor the driver and front passenger windows in both my and my wife's cars but now instead of being 1/3 defective they are both 2/3 defective. If I wasn't upset before, I am now.
I was
Did you manually default the cameras settings after updating the firmware? If not, I would do that and test again.
I don't think a reset or new settings will help anymore.
This model has a common issue that crops up after three years of use.
I overlooked that he is referring to the T130. I quickly read the post and was thinking of the newer T models. My bad.
However, since they are saying things got worse after the firmware update, it may still be worth trying.
  • I have reset with a paperclip
  • I have reset with the app
  • I have reset with a paperclip while inserting the power cord
  • I have rebooted with the power button
  • I have removed/reconnected the power cord
  • I have swapped rear cameras
  • I have swapped rear camera cables
  • I have reformatted the SD cards
My preferred outcome is to have both T130s repaired/replaced due to failure as a result of manufacturing/design defect.
Until then, I'm hoping there is a way to downgrade the firmware to what it was to see if I can at least get one (or preferably both) units to have 2-camera functionality again.
As far as I know, nothing will help.
The only solution is to replace the main unit.
I've been asking to add one sentence to all User Manuals.
This would solve & prevent a lot of tech support inquiry.
"Please perform Factory Reset / Default Settings after successful Firmware Update"
NOTE: You may back up custom settings with Export Settings before proceeding.
In times like these, it helps to play 'nice' and look for opportunities. You're unlikely to get two new T130S because of availability, though it is possible. I would see if Viofo will work with you on replacing both of those T130s with a comparable model at a reduced price.
I duplicated similar errors by inserting the FFC ribbon cable at an angle, where the last two end leads aren't properly seated. If you remove the ribbon cable, note the orientation at both ends and gently clean it with a liquid cleaner like DeoxIT F5; you can also clean the connector. F5 should not harm the average circuit board.
More likely, though, a component on the board has failed.
I'm working with Viofo on a resolution but I'll rephrase something from my previous post; Can someone tell me how to or help me downgrade the firmware to an earlier version? I don't know what the version was before I updated to V1.2_0505.
You can install any firmware version on the T130.
How?
It is written below:
Please format the SD card first and then download the bin file to the card and power the camera with the card inserted. Here is a video. for your reference. You can put both front and rear camera bin files to your card in case you want to flash both the main body and rear camera.
Taken from here:
