killoverme
- Jan 11, 2016
- Canada
So I have an issue with my G1WH (only 10 months old) ![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
Basically I found out that it wouldn't turn on (because the battery was 'dead') I tried replacing the battery and that didn't really solve it. The unit powers on fine with 'just battery'. However it does not run via usb.
Basically when I plug it in via usb, it auto turns on and then once loaded (says goodbye and turns off). When I power it on manually it turns on and I can record and such. However the battery indicator always shows a battery and never the plugged in symbol (even though the usb is plugged in).
The blue charge light is on when it is plugged it and i checked the voltage and power is going to the batteries (so it is being charged).
I've also tried the g1wc firmware (but there was no display, however taking a picture worked and I'm sure there is a way to record as well) [I put a supercap when testing this].
I did a visual inspection and the board seems fine...
Any help? Also is there any other g1wc firmware I could try (I tried the one at spytec).
I have also tried various g1wh firmwares and the usb connector is not loose.
