Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
Edit: So looks like Z7 is the winner over G1WH.
1. Z7's daytime video is better in color and focus.
2. Z7's night video also is slightly brighter with more details in darker areas but has blue blotches all over in the dark areas.
3. Z7 has true IR lights instead of regular bulb in G1WH.
4. Z7's FOV is slightly wider than G1WH even though both claim 140 degrees.
5. Most importantly, Z7 is half the size of G1WH.
-->This one alone makes it a winner plus it performs equal or better than G1WH in every way.
G1WH does have option of various firmware and CPL options that Z7 doesn't have yet.
Edit:
Gearbest has Z7 on sale for $41.99 including free shipping with DOMEZ7 coupon code.
Original thread starts from here on...
This thread is a review of Dome Z7 dashcam from www.gearbest.com
I didn't find brand/model section for this dashcam so I'm starting a thread here.
If there is a brand/model section where this dashcam belongs to, please move it there.
Product link is below:
Specifications: --> Specifications are pretty much same as G1WH.
Brand: DOME
Model: Z7
Type : HD Car DVR Recorder, Full HD Dashcam
Chipset Name: Novatek
Chipset : Novatek 96650
External Card : TF 32G (not included)
Special Function: Motion detection, Photograph, HDMI output, Cycle recording, Digital zoom
Battery type: Built-in
Capacity : 230mAh lithium battery
Charge Way : Car charger
2.0 inch LCD screen, 1080P FULL HD video
Advanced H.264 photography compression technology
4X digital zoom
10.0MP image resolution
140 A+ grade high-resolution wide angle lens
30 frames per second for smooth video flow
Support HDMI full HD video transmission
Seamless loop-cycle recording function
Motion detection function
G-sensor function
Check the above link or click here for more details...
The dashcam product box came in a brown cardboard box with bubble wraps.
No damage anywhere.
Z7 came with a USB to micro-usb cable, micro-usb car charger and car suction mount.
Unlike other dashcams like G90 and G1WH, this uses micro usb, not mini.
It's better for consumers like me with smart phones as most use micro usb nowadays.
The car mount is smaller but exactly like that of the G1WH except there is a small tab to release the dash cam after it's locked. I think this will help it lock on the mount better as the G1WH mount is not that tight fit.
Size:
Dome Z7 only around 2.25 inches square and lens does not protrude out of the body too far so very small compared to G1WH which is double the size of Z7.
For those who are looking for smaller size, this may be the ticket if the video quality is as good as G1WH.
Here is how Z7 looks against G1WH and G90:
Front view: It has microphone hole, two IR lights and the lens on the front.
Label on the front:
FULL HD 1080P
HIGH DEFINITION
Buttons:
Top has car mount and micro-usb power jack.
Here is what the small tab looks like on the car mount:
Left side has power, REC and MODE buttons along with a 3.5mm jack, may be for AV out. I don't think it is for GPS logging.
REC button also acts as 'OK' or select button for the menu options.
Right side has reset hole, up/down and M (Menu) buttons:
Bottom side has microSD slot and mini HDMI out:
Menu options are very similar to G1WH.
I'll post test videos next...
Edit:
Brand: DOME
Model: Z7
4X digital zoom
G-sensor function
No damage anywhere.
Size:
Label on the front:
FULL HD 1080P
HIGH DEFINITION
Buttons:
