DennisOlof
What is the difference with this new lens ? is it better than the old 90 lens ?
But with the 2 dashcams you get 2 free fisheyes, the GitUp 13 glass lens doesn't have any13 glassthats like 2 mid range dashcams from China.
For the 4.35mm lens version, the MOD is 100mm.DAMM gitup they dont make it easy to stay avay from ther product, any one know what the MOD is for that lens ?
But it is too long for the waterproof case, correct?It's in final editing, almost done, it may me possible that I post it later today or tomorrow.
GTwoBlues, might be, same thing for gopro. But I did read or watch a video where they had a narrow FOV lens for the gopro that did not stick out, but
you have to place some sort of gasket or sealing ring around it.
But otherwise you are correct, the rules of math, optics etc can not change, all you can do is adapt to the conditions you have, and create a sensor
or lens around the limitations. Otherwise you would have to make changed to the product it self. Not that much you can do about it, and I do think
there was (or is) a case for the gopro that will allow you to use a longer lens, not sure though.
It should be the same for gitup camera as well, there is a replacement lens for sony actioncams and they stick out as well. So you can not use the
underwater case.
God Morgon DennisOlof:TwoBlues, might be, same thing for gopro. But I did read or watch a video where they had a narrow FOV lens for the gopro that did not stick out, but
underwater case.
Definitely, if you are in need of a myriad of accessories, and cost is no concern, Gopro is the action cam for you! However you cannot expect your Hero 4 black to film in 4k for as long as you want to! Can you??Yeah I understand that, if you change something about the camera, it is possible that the case does not fit. This is also the reason for all
the accessories for the gopro, and even third party stuff. They where first and have the most things for their cameras. Compared to other
brands. But then again, premium price, and then you would expect premium accessories.
Good for me I do not have the need for a waterproof case, but who knows, might come in handy some day ?
Please define MOD. Is that "Max.Outside Dia.?"For the 4.35mm lens version, the MOD is 100mm.
Gitup's responder mentioned 4.35mm. I think that's the focal length, because the standard lens is 3 mm. It is 4 pm I expect the person we converse with will be online in 18 hours or so.A lens twice the width of the Git2
How about Minimum Object Distance?
Yes, that will be the focal length.Gitup's responder mentioned 4.35mm. I think that's the focal length, because the standard lens is 3 mm. It is 4 pm I expect the person we converse with will be online in 18 hours or so.
Mike
Minimum Object distance is the closest point at which it can be focused, but since there is no focus mechanism on the Git2 I guess it is not a significant figure for most people.
I mean the Minimum Object Distance, I got this answer from lens manufacture.A lens twice the width of the Git2
