Gitup Git 2 -only orange logo screen "Gitup".
Nabuchodonozor
Poland
Hello, I have a problem with Gitup Git 2. When shows only orange logo screen "Gitup" and so is frozen. It does not help to install the firmware . Please help.
it's the same. Same is to take out the battery and plug in the power.
I did not do anything with the software prior to the occurrence of this problem.
you could try reloading the firmware, the bootloader starts befre the camera does (sort of like your computer BIOS) so even the camera won't start now you may still be able to reload the firmware
Does it make any beep sound with or without external battery? Any of led lamps the flashing? Try to remove the battery lock, and with your finger press it little harder to the Contacs, and Try start it. My git had same issue but with beep sounds and it were running in auto start mode (car mode) so it totaly locked down with this issue, i fixed it with some papper between the battery and the hatch/lock. Good luck!
It starts with three beeps. Unfortunately it helps hold the battery - checked on two different batteries. I think I can write off camera ...
Put some paper between the hatch and the battery.. So the battery is more fixed in position..
Normally this may caused the by the sensor board connection, it require to open the camera to check the connection.
