GPS location on map .
laffenxxx
Norway
I got my 0806 and all work ok . I have 2x 128 GB cheap ebay sdcards in my camera and sometimes i get message card size limit and it dont record ( this happend also with Kingston 8 GB class 10). When i push record button several times its start recording. I bought 3 gps mountings and all of them give same gps signal . Why is this locating wrong ? See photo .... im driving number 29 left on photo and i stop where i put marker shows like a hand .
Straight off your 128GB cards are more than likely fake so you probably want to run them through h2testw and then replace them
Which software are you using to display the map?
Is Registrator Viewer more accurate? http://www.registratorviewer.com/download_en.html
If all three give the same position and on more than one day then it must be either the map is wrong or more likely the software.
Registrator Viewer allows you to select different maps.
As Reverend says, the 128GB card is probably an 8GB one which someone has added "12" in front of the "8GB", real 128GB cards are not cheap.
I have tried several viewers and actually the one i like the best is RegistratorViewer. The map i use in it is Leaflet (i think) but i know that i like several styles. For the fun i suspect this is about where you had stopped. (just for fun, nothing to help you, just for fun)
Your all very correct 🙂 RegistratorViewer show it different so i think its the map/software i used . My SD card say 128 gb but only 7,7 gb working ...rest is corrupt , and i saw ebay already send me mail about this seller because they had removed him . Will use ebay buyer protection . And yes i had read about that it was some fake Cards on ebay before i bought it 😛.
And for PurpleMoon, yes this is almost correct im been living this area all my life and this is my neigbours place that he use for storing things from his small farm ....he dont live there and this streetview photo is old because the houses isnt there anymore. I can tell you that i had to laugh when i saw this photo this morning 🙂🙂 . Thanks .
