this design is public tooling, there are many suppliers that use the same housing and put their own internals in them, very hard to know which version it might be
i'm searching because i't seems that the camera bricked when i changed the sd card, the wifi led stays on and does not record.
thanks for the reply!
what card did you use, if it's not formatted correctly it will lock up and nothing will happen
try it with no card and see if you can access with the app
Yes, if i try with no card i can access on the app with no problem but as soon i insert any sd card it turn off wifi (even with an sd card that i've been using before)
what card are you using?
Hey, welcome to the club.
Does your dashcam have ANY info on it? Model number?
What app are you using to check on the camera?
How does the 8GB folder structure look compared to your 32GB folder/s?
You might need to format the 32GB card and put some firmware in the 32GB card.
do a full overwrite erase of the 32GB card in your computer using SDFormatter and then try it in the camera
