Totally empty battery charged for 15 hours, and here are the results:
1. first of all, the european adapter is too narrow, it hardly has a good contact or connection to the socket:
2.
plugged in:
- 44 mA
- 4,7 W
- 0 kWh
- recording time = on time = 0,09 h = 5 min
- camera screen: nothing special
The red light (LED) was blinking: bright-dimmed-bright-dimmed, and so on.
15 hours later it was blinking: bright-off-bright-off.
What's the code here ? When bright, when dimmed, when off ?
After 15 hours:
- 30 mA
- 3,6 W
- 0,058 kWh
- recording time = on time = 15,62 h = 15 h 37 min.
So far so good.
The problem started, when I wanted to turn the record
off. I pushed the REC/OK button, and the camera went in to an endless loop of messages:
Max file size reached !Storage 10 error ! Max file size reached !Storage 10 error !
No button responded, push or press&hold - nothing. So the next step is a
Reset button.
The camera responded to it and switched
off.
Switched it back on, and found another
invalid file:
Unfortunatelly, in that confusion with error-messages I forgot to write down the recording time from the camera LCD. That might help to a better analysis of what was going on.
This is a consuption of a "stand-alone" mains charger, no camera attatched: it sure has some consumption, otherwise that annoying red LED would not be
on, but not enough for the energy meter to detect:
The last step was to test the fully charged battery life.
Turned the camera
on, record
on, no auto-turn-off, no LCD-off.
The red battery symbol, indicating it's empty, appeared after 24 minutes.
The camera said "no power" and "Bye-bye" after 29 minutes.
I guess 29 minutes of life for a fully charged battery of that size is a normal result, right ?
What worries me, is increasing number of stored files marked as
invalid, unusuall behaviour of a camera with error-messages, and above all why I did this test in the first place - how come the battery didn't charge in a car to work without power for at least 30 seconds, but the camera was working well when plugged in a cigarette lighter.
Like previously mentioned, I pushed the reset-button, so if it was a software error, it must go away.
What I'm gonna do next, is format the memory card (Kingston 32GB class 10).
Any other ideas ?
