Carlarala
- Aug 20, 2014
- United Kingdom
- GS8000L no GPS
I have recently purchased the GS8000L Dash Cam.
I purchased a 32GB SD Micro Card Class 10 (not branded)
I have tried using it several times using different Resolutions 1080P, HD or 720P but it records intermittently and stops every 10 or so seconds then begins again with 3/4 second delay between each recording. It's like watching screen shots as opposed to a video at some parts.
I have tried formatting the SD card on my PC using Fat32. I am not sure which unit allocation size to use. I have tried formatting it at 32kilobytes or 64kilobytes but it still won't record continuously for more than anything between 9-19 seconds at a time.
The options for formatting I have are
CAPACITY 30.6GB
ALLOCATION UNIT SIZE
Default allocation size
512 bytes
1024 bytes
2048 bytes
4096 bytes
8192 bytes
16 kilobytes
32 kilobytes
64 kilobytes
The settings on the Dash Cam for recording I am using are...
RESOLUTION 1080HFD 1920x1080 (Also tried using 1080P 1440x1080 & 720P 1280x720)
LOOP RECORDING 5 minutes (Also Off, 3minutes, 5minutes or 10minutes)
MOTION DETECTOR off
AUDIO on
DATE STAMP on
G-SENSOR SENSITIVITY High (Options Off, Low, Medium or High)
It may be something as simple as the SD card may not be compatible or I am not formatting the SD card on the correct setting)
Any advice would be much appreciated.
CAPACITY 30.6GB
512 bytes
1024 bytes
2048 bytes
4096 bytes
8192 bytes
16 kilobytes
32 kilobytes
64 kilobytes
MOTION DETECTOR off
AUDIO on
DATE STAMP on
