Spyman99
- May 7, 2015
- France
- France
- DR600GW, A118, Mini 0806 and more...
Hello everybody,
Let me introduce you, with our partner GearBest, the Shadow GT880S. The first dashcam by Seezeus with OBD connection to the vehicle.
This dashcam offers a maximum recording resolution of 1080p at 30fps with WDR. The generated videos are in MOV format.
The viewing angle is 148 ° and the lens offers an aperture of f1.6 assisted by a 1/3 " CMOS sensor .
It is equipped with a GPS, a 3-axis accelerometer, a microphone and a speaker.
It also has a HDMI video output for a direct view on your TV screen.
The storage is done on an external memory card by a MicroSD slot. The maximum capacity is 32 GB.
The menus of the GT880S are multilingual including English of course (and French for me ).
The GT880S also offers other features such as Fatigue Driving Warning, Speed Limit Warning but also a Parking Mode.
The parking mode shoots in low frame rate in order to limit the space on the memory card. You can choose a rate of 1, 2 or 5 frames / sec.
Regarding the videos, the GT880S allows to record data such GPS coordinates, date / time and plate number or personal information.
But the interesting thing is that it can also include data from information supplied by the OBD connection.
On its 2.7’’ LCD display, the GT880S also displays, in screen saver mode, some parameters of the OBD (engine load, coolant temperature, error code, speed, mileage, the battery voltage and the stroke of the accelerator) or GPS speed with a compass and GPS coordinates. Otherwise, the display can also be turned off.
An image reversal function is also available: you can also use the camera placed on the dashboard for example.
______________________________________________________________________________
Back to the OBD function:
What is the OBD? ?
For this, I invite you to read the following link for more information: http://en.wikipedia.org/wiki/On-board_diagnostics
OBD cable is supplied with the dashcam and is used to supply power. The male connector is connected to the diagnostic female plug of your vehicle.
Then the GT880S is able to record information on the videos as battery voltage, speed, engine rpm, coolant temperature, ...
15 parameters can be shown on the videos. These parameters may or may not appear depending on the brand / model of the vehicle because despite the OBD protocol is a standard: it may happen that the GT880S can not read certain data.
Below the 15 concerned parameters:
1.Battery Voltage (V)
2. Engine Revolution Speed (rpm)
3. Driving Speed (Km/h)
4. Throttle Percentage (%)
5. Engine Load (%)
6. Coolant Temperature (°C)
7. Average Fuel consumption (L/h)
8. Instantaneous Fuel consumption (L/100km)
9. Current Mileage (km)
10. Total Mileage (km)
11. Fuel Consumption (L)
12. Accumulated Fuel Consumption (L)
13. Fault Quantity
14. The times of urgent Acceleration (Times)
15. The times of sharp slow down (Rapid Deceleration) (Times)
If possible, the GT880S is able to display and erase error codes of the vehicle but only the codes without gravity. If you have an injection issue, for example, the GT880S will not be able to indicate.
For example, here is a screenshot realized with my Renault Laguna 3 car :
As said earlier, you will notice that there are only 12 listed parameters and one of them remains at 0: Percentage Throttle. This confirms that all parameters are not accessible / enabled depending of the brand / model of the vehicle.
Other photos:
[size=8pt]Photo credit: Spyman99[/size]
Features:
Sensor: 1/3" CMOS
View angle: 148°
LCD Display: 2.7" TFT
Aperture: f1.6
Resolution:
1920x1080p@30fps
1280x720p@30fps et @60fps
848x480p@30fps
640x480p@30fps
WDR: yes
G sensor: yes, 3 axis
Video format: MOV
Connection port: USB 2.0 and HDMI out
GPS: yes
OBD: yes
Storage: MicroSDHC up to 32Gb
Battery: 300mAh
Size: 113mm(L) x 32mm(P) x 45.5mm(H), weigth: 103gr
T° storage: -20°C~85°C
Accessories: 1x HDMI cable, 1x OBD cable, 1x suction mount, 1x adhesive mount, 1x USB MicroSD memory card reader, 1x manual, 1x installation CD
Videos:
By day:
twilight:
By night:
What is the OBD? ?
5. Engine Load (%)
13. Fault Quantity
Other photos:
Features:
Sensor: 1/3" CMOS
View angle: 148°
Aperture: f1.6
Resolution:
1920x1080p@30fps
848x480p@30fps
640x480p@30fps
WDR: yes
Video format: MOV
GPS: yes
OBD: yes
Battery: 300mAh
Videos:
By day:
twilight:
By night:
